- To:
- Subject: Re: [cgal-discuss] Point .... dim=1 form an edge but do not intersect
- Date: Wed, 08 Oct 2014 10:42:53 +0200
Le Tuesday 07 October 2014 17:12:25 Ruud Vlaming a écrit :
> Hey Guys,
> I get the error:
> Point p[-9.91211 -13.5246 -10.8856], dim=1 and q[-9.9571 -13.5666 -10.9184],
> dim=1 form an edge but do not intersect ! CGAL error: assertion violation!
> Expression : minimal_size_ > 0 || c3t3_.is_valid()
> File : /opt/local/include/CGAL/Mesh_3/Protect_edges_sizing_field.h
> Line : 370
> and stumbled on this link:
> http://cgal-discuss.949826.n4.nabble.com/Problem-when-meshing-polyhedron-wi
> th-sharp-features-td4659217.html
> Are those issues solved in CGAL 4.4_0?
> If so, what might be causing this? The stl used
> was checked with MeshLab to be singly connected,
> but has same very sharp features and "tunnels".
> Thank you for any assistance.
There is a bug in the file <CGAL/Mesh_3/Protect_edges_sizing_field.h>, in
CGAL-4.5-beta1. I assume that you are using that version of CGAL. The bug is
not present in the previous released version CGAL-4.4, and it will be fixed
in
next version CGAL-4.5, coming soon.
Laurent Rineau, PhD
- [cgal-discuss] Point .... dim=1 form an edge but do not intersect, Ruud Vlaming, 10/07/2014
- Re: [cgal-discuss] Point .... dim=1 form an edge but do not intersect, Laurent Rineau (CGAL/GeometryFactory), 10/08/2014
- Re: [cgal-discuss] Point .... dim=1 form an edge but do not intersect, Ruud Vlaming, 10/08/2014
