- To:
- Subject: [cgal-discuss] debug and release versions
- Date: Mon, 13 Oct 2014 19:26:29 +0200
Hi,
What is the strategy to build both debug and release versions of CGAL
on Windows 64 bit MSVC 2012 with corresponding debug and release
versions of BOOST? I try things like
cmake -DBOOST_LIBRARYDIR:PATH=C:/boost_1_55_msvc-11.0_lib_x64/\$(Configuration
but cmake configuration fails saying that boost libs are not found. If
I use "release" and "debug" explicitly then it works, but then I have
to make two separate builds for debug and release.
Can you please advise?
Thanks
Dominik
- [cgal-discuss] debug and release versions, Dominik Szczerba, 10/13/2014
- Re: [cgal-discuss] debug and release versions, Sebastien Loriot (GeometryFactory), 10/23/2014
