- To:
- Subject: Re: [cgal-discuss] debug and release versions
- Date: Thu, 23 Oct 2014 09:34:02 +0200
On 10/13/2014 07:26 PM, Dominik Szczerba wrote:
Hi,have you tried following the tutorial at
What is the strategy to build both debug and release versions of CGAL
on Windows 64 bit MSVC 2012 with corresponding debug and release
versions of BOOST? I try things like
cmake -DBOOST_LIBRARYDIR:PATH=C:/boost_1_55_msvc-11.0_lib_x64/\$(Configuration
but cmake configuration fails saying that boost libs are not found. If
I use "release" and "debug" explicitly then it works, but then I have
to make two separate builds for debug and release.
Can you please advise?
Thanks
Dominik
http://www.cgal.org/windows_installation.html
The selection of debug and release version of boost depending on the
option in MSVC is then automatic.
Sebastien.
- [cgal-discuss] debug and release versions, Dominik Szczerba, 10/13/2014
- Re: [cgal-discuss] debug and release versions, Sebastien Loriot (GeometryFactory), 10/23/2014
