- To:
- Subject: [cgal-discuss] Mesh a portion of an implicit surface
- Date: Thu, 6 Nov 2014 12:39:45 -0800 (PST)
Hello all,
I've managed to create a mesh from a point set using the Poisson
reconstruction example.
I'm interested in meshing only a portion of this surface though rather than
the entire thing (for the purposes of hole filling).
In the documentation on mesh generation
<http://doc.cgal.org/latest/Surface_mesher/index.html#SurfaceMesher_section_criteria>
I noticed this: "The meshing algorithm requires to know the surface to be
meshed only through an oracle able to tell whether a given segment, line or
ray intersects the surface or not and to compute an intersection point if
any. This feature makes the package generic enough to be applied in a wide
variety of situations."
and hoped it meant I was able to give it a small starting mesh and it return
a corresponding mesh which intersects the implicit surface. I'm a little
confused on how to implement this though, all the implicit surface functions
seem to use a bounding sphere, suggesting to me the whole surface will be
meshed.
Can anyone provide a small sample of code to put me on the right track?
All help greatly appreciated,
Wiredchop
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-a-portion-of-an-implicit-surface-tp4660055.html
- [cgal-discuss] Mesh a portion of an implicit surface, Wiredchop, 11/06/2014
- Re: [cgal-discuss] Mesh a portion of an implicit surface, Laurent Saboret, 11/07/2014
