cgal-discuss - [cgal-discuss] Calling delete_cell() on a Delaunay triangulation
  • To:
  • Subject: [cgal-discuss] Calling delete_cell() on a Delaunay triangulation
  • Date: Thu, 6 Nov 2014 20:12:42 -0800
Hello all,
I have a function on a Delaunay triangulation which checks the validity of my cells. I want to call TriangulationDataStructure_3::delete_cell(). How do I do that?
First, I tried just doing Tds::delete_cell(cit);
But that gives a “call to non-static member function without an object argument”.
Next, I tried calling the superclass method from the subclass:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
/// Used so that each timeslice is assigned an integer
typedef CGAL::Triangulation_3<K>  Triangulation;
typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
typedef CGAL::Triangulation_data_structure_3<Vb> Tds;
typedef CGAL::Delaunay_triangulation_3<K, Tds> Delaunay;
typedef Delaunay::Vertex_handle Vertex_handle;
typedef Delaunay::Locate_type Locate_type;
typedef Delaunay::Point Point;
inline bool check_timeslices(Delaunay* D3) {
  Delaunay::Finite_cells_iterator cit;
  for(cit = D3->finite_cells_begin();  cit != D3->finite_cells_end(); ++cit)
    /// Get the vertices from the cell
    //Delaunay::Facet& face = *(cit->first);
    // Vertex_handle vs = cit->source();
    if (cit->is_valid())
        std::cout << "Cell is valid." << std::endl;
    else
        D3->Tds::delete_cell(cit);
        std::cout << "Invalid cell destroyed." << std::endl;
  assert(D3->is_valid());
  return true;
It looks like delete_cell is a private function not callable from subclasses. I get:
[ 12%] Building CXX object CMakeFiles/cdt.dir/src/cdt.cpp.o
In file included from /Users/adam/CDT-plusplus/src/cdt.cpp:22:
/Users/adam/CDT-plusplus/src/S3Triangulation.h:59:13: error: 'Tds' is a private
      member of 'CGAL::Triangulation_3<CGAL::Epick,
      CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
      int, CGAL::Epick, CGAL::Triangulation_vertex_base_3<CGAL::Epick,
      CGAL::Triangulation_ds_vertex_base_3<void> > >,
      CGAL::Triangulation_ds_cell_base_3<void>, CGAL::Sequential_tag>,
      CGAL::Default>'
/usr/local/include/CGAL/Triangulation_3.h:375:83: note: implicitly declared
      private here
  ...Triangulation_cell_base_3<GT> > >::type Tds;
/Users/adam/CDT-plusplus/src/S3Triangulation.h:59:18: error:
      'CGAL::Triangulation_data_structure_3<CGAL::Triangulation_vertex_base_with_info_3<unsigned
      CGAL::Sequential_tag>::delete_cell' is not a member of class 'Delaunay'
      (aka 'Delaunay_triangulation_3<K, Tds>')
