cgal-discuss - Re: [cgal-discuss] Add user defined information to vertex/face using 2D voronoi diagram adapter
  • To:
  • Subject: Re: [cgal-discuss] Add user defined information to vertex/face using 2D voronoi diagram adapter
  • Date: Tue, 11 Nov 2014 23:13:13 -0800
Here, the vertex is extended to hold an unsigned int.
You can do the same thing for the faces. For example (just modified the above example):
https://gist.github.com/alextsui05/a2d805a9a6f9635d44fb
Please post code you might have trouble with.
Good luck,
--Alex
On Mon, Nov 10, 2014 at 10:54 PM, Kazuyo Mizuno <> wrote:
Hello all.
I'm currently implementing a program using 2D voronoi diagram adapter
described as follows.
http://doc.cgal.org/latest/Voronoi_diagram_2/index.html
I want to add information (ex: ID number) to each face/vertex of
voronoi diagram.
I have tried to use following class but failed.
http://doc.cgal.org/latest/Triangulation_2/classCGAL_1_1Triangulation__vertex__base__with__info__2.html
Is there any way to do so?
Regards
Kazuyo Mizuno
