cgal-discuss - Re: [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used
  • To:
  • Subject: Re: [cgal-discuss] Restore valid Delaunay triangulation after tds().delete_cell(cit) is used
  • Date: Tue, 11 Nov 2014 23:02:50 +0100 (CET)
On Tue, 11 Nov 2014, Adam Getchell wrote:
I am storing some timeslice data in each vertex of a 3D Delaunay
triangulation, and then ensuring that each cell is correctly foliated (i.e.
maximum timeslice - minimum timeslice == 1).
For those cells that fail this criteria, I delete them using
tds().delete_cell(cit).
https://github.com/acgetchell/CDT-plusplus/blob/master/src/S3Triangulation.h
However, this produces an invalid triangulation.
How do I fix these holes?
What do you mean? The Delaunay triangulation is uniquely determined by the points. If you remove a cell, "fixing" the triangulation means adding that cell back...
Or maybe what you want is not a triangulation?
Marc Glisse
