- To:
- Subject: Re: [cgal-discuss] Performance regression in Mesh Simplification Package?
- Date: Wed, 12 Nov 2014 21:11:35 +0100
Could you give more detail on your configuration because I
ran the example on my machine with your input and got the following
result:
CGAL-4.4: 32.468s
CGAL-4.5: 12.321s
Sebastien.
On 11/12/2014 04:11 PM, tlanglois wrote:
Hi everyone,
There seems to be a performance regression in the Mesh Simplification
package between CGAL 4.4 and 4.5. The simplest example I can give is based
example 4.7 in the Triangulated Surface Mesh Simplification User Manual
page. When I build this example and run it on a large mesh (link for a
highly tesselated sphere below), the 4.4 version finishes in under a minute.
The 4.5 version is still running, I estimate it will take several hours. The
collection stage is fast in both, but in 4.5 the collapse stage is very
slow.
Has anyone else noticed this? I'm not sure exactly what's going on. The
first thing that comes to mind is did the default storage containers used in
the Polyhedron class change in some way that makes edge collapse operations
slower?
Highly tesselated sphere I'm using for testing:
https://www.dropbox.com/s/po6k7fgy5s318uz/sphere.off?dl=0
Thanks,
Tim
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Performance-regression-in-Mesh-Simplification-Package-tp4660088.html
- [cgal-discuss] Performance regression in Mesh Simplification Package?, tlanglois, 11/12/2014
- Re: [cgal-discuss] Performance regression in Mesh Simplification Package?, Sebastien Loriot (GeometryFactory), 11/12/2014
- Re: [cgal-discuss] Performance regression in Mesh Simplification Package?, tlanglois, 11/13/2014
