cgal-discuss - Re: [cgal-discuss] Performance regression in Mesh Simplification Package?
  • To:
  • Subject: Re: [cgal-discuss] Performance regression in Mesh Simplification Package?
  • Date: Wed, 12 Nov 2014 15:29:14 -0800 (PST)
Hmm, that's interesting. I'm using Arch Linux. The full CMAKE output for the
4.5 build is below. I did not change any compiler flags or anything. All of
the required libraries were installed from the Arch repositories, and are
the same for my 4.4 and 4.5 builds. Thanks for your help.
-- The CXX compiler identification is GNU 4.9.2
-- The C compiler identification is GNU 4.9.2
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
== Setting paths ==
-- Build CGAL from release in directory CGAL-4.5
-- Packagenames: CGAL-4.5
== Setting paths (DONE) ==
== Generate version files ==
-- CGAL_MAJOR_VERSION=4
-- CGAL_MINOR_VERSION=5
-- CGAL_BUGFIX_VERSION=0
-- CGAL_SONAME_VERSION=10
-- CGAL_SOVERSION =10.0.4
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- USING CMake version: 3.0.2
-- System: Linux
-- USING GCC_VERSION = '4.9.2'
-- Using gcc version 4 or later. Adding -frounding-math
== Generate version files (DONE) ==
== Set up flags ==
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING LDFLAGS = ' '
== Set up flags (DONE) ==
== Detect external libraries ==
-- External libraries supported:
GMP;GMPXX;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE
-- Preconfiguring library: GMP ...
-- Found GMP: /usr/lib64/libgmp.so
-- GMP has been preconfigured:
-- UseGMP-file:
-- GMP include: /usr/include
-- GMP libraries: /usr/lib64/libgmp.so
-- GMP definitions:
-- USING GMP_VERSION = '6.0.0'
-- Preconfiguring library: MPFR ...
-- Found MPFR: /usr/lib64/libmpfr.so
-- MPFR has been preconfigured:
-- UseMPFR-file:
-- MPFR include: /usr/include
-- MPFR libraries: /usr/lib64/libmpfr.so
-- MPFR definitions:
-- USING MPFR_VERSION = '3.1.2'
-- Boost version: 1.57.0
-- Found the following Boost libraries:
-- thread
-- system
-- Boost include: /usr/include
-- Boost libraries:
/usr/lib64/libboost_thread.so;/usr/lib64/libboost_system.so
-- Boost definitions:
-- USING BOOST_VERSION = '1.57.0'
== Detect external libraries (DONE) ==
== Write compiler_config.h ==
-- Performing Test CGAL_CFG_BOOST_VARIANT_SWAP_BUG - Success
-- Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
-- Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
-- Performing Test CGAL_CFG_IEEE_754_BUG - Success
-- Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_6 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_7 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_8 - Success
-- Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Success
-- Performing Test CGAL_CFG_NO_LIMITS - Success
-- Performing Test CGAL_CFG_NO_NEXTAFTER - Success
-- Performing Test CGAL_CFG_NO_STL - Success
-- Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Success
-- Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
-- Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
-- Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
-- Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
-- Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
== Write compiler_config.h (DONE) ==
== Generating build files ==
Configuring libCGAL
-- Requested component: MPFR
-- Requested component: GMP
libCGAL is configured
-- Sources for CGAL component library 'CGAL_Core' detected
Configuring libCGAL_Core
libCGAL_Core is configured
-- Sources for CGAL component library 'CGAL_Qt4' detected
Configuring libCGAL_Qt4
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so -
found
-- Looking for gethostbyname
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib64/libX11.so
-- USING OPENGL_VERSION = '2.1'
-- USING QT4_VERSION = '4.8.6'
-- OpenGL include: /usr/include
-- OpenGL libraries:
/usr/lib64/libGLU.so;/usr/lib64/libGL.so;/usr/lib64/libSM.so;/usr/lib64/libICE.so;/usr/lib64/libX11.so;/usr/lib64/libXext.so
-- OpenGL definitions:
-- Qt4 include: /usr/include/qt4
-- Qt4 libraries:
/usr/lib64/libQtOpenGL.so;/usr/lib64/libQtGui.so;/usr/lib64/libQtCore.so
-- Qt4 definitions:
-- moc executable: /usr/lib/qt4/bin/moc
-- uic executable: /usr/lib/qt4/bin/uic
libCGAL_Qt4 is configured
-- Sources for CGAL component library 'CGAL_Qt3' detected
Configuring libCGAL_Qt3
-- libCGAL_Qt3 needs Qt3, cannot be configured.
-- Sources for CGAL component library 'CGAL_ImageIO' detected
Configuring libCGAL_ImageIO
-- Found OpenGL: /usr/lib64/libGL.so
-- Found ZLIB: /usr/lib64/libz.so (found version "1.2.8")
-- USING ZLIB_VERSION = '1.2.8'
libCGAL_ImageIO is configured
-- Sources for CGAL component libraries
'CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt4' detected
== Generating build files (DONE) ==
-- Configuring done
-- Generating done
-- Build files have been written to: /home/langlois/Downloads/CGAL-4.5
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Performance-regression-in-Mesh-Simplification-Package-tp4660088p4660098.html
