- To:
- Subject: [cgal-discuss] Problem with building polyhedron
- Date: Wed, 19 Nov 2014 07:43:51 -0800 (PST)
Hello everyone,
I'm having problem with building a polyhedron from points. What i'm doing is
like the following;
1. Create a sphere from implicit function:
//some code before
CGAL::make_surface_mesh(c2t3, surface, criteria,
CGAL::Non_manifold_tag());
2. Insert the mesh points into a list:
//some code before
Tr::Point_iterator iterator;
for(iterator = tr.points_begin(); iterator != tr.points_end();
iterator++){
Point p(iterator->x(), iterator->y(), iterator->z());
points.append(p);
3. Build the polyhedron from these points:
template <class HDS>
class Build_triangle : public CGAL::Modifier_base<HDS> {
public:
QList<Point> pts;
void setPoints(QList<Point> prmt){
pts = prmt;
Build_triangle() {}
void operator()( HDS& hds) {
// Postcondition: hds is a valid polyhedral surface.
CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
B.begin_surface(pts.length(), pts.length()/3, 0);
typedef typename HDS::Vertex Vertex;
typedef typename Vertex::Point Point;
for(int i=0;i<pts.length(); i++){
B.add_vertex( Point( pts[i].x, pts[i].y, pts[i].z));
B.begin_facet();
B.add_vertex_to_facet( i);
B.end_facet();
B.end_surface();
//Some code here...
Polyhedron P;
Build_triangle<HalfedgeDS> triangle;
triangle.setPoints(points);
P.delegate( triangle);
But when i do that, i get a line instead of a sphere. What am i doing wrong?
Thanks.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-building-polyhedron-tp4660132.html
- [cgal-discuss] Problem with building polyhedron, Omer Ozturk, 11/19/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] Problem with building polyhedron, Sebastien Loriot (GeometryFactory), 11/20/2014
