- To:
- Subject: Re: [cgal-discuss] Face_handle from face?
- Date: Tue, 25 Nov 2014 12:55:40 -0600
That works well for a for loop, but not for an STL algorithm like for_each like this:
std::for_each(cdt.finite_faces_begin(), cdt.finite_faces_end(), DoSomething())
where DoSomething is a functor. DoSomething gets *fit instead of fit, which is a face. I'd like to call cdt.triangle, but that only accepts Face_handles.
On Tue, Nov 25, 2014 at 12:45 PM, Chris Marsh <> wrote:
I do this:for (Delaunay::Finite_faces_iterator fit = this->finite_faces_begin();fit != this->finite_faces_end(); ++fit){Delaunay::Face_handle face = fit;Where Delaunay is justtypedef CGAL::Delaunay_triangulation_2<Gt, Tds> Delaunay; //specify a delauany triangulationCheersChrisOn Tue, Nov 25, 2014 at 12:41 PM, Jack Stalnaker <> wrote:How do I get a Face_handle from a face? If I use a finite_faces_iterator in an STL algorithm, it dereferences the iterator to a face, but I'd like to use Triangle CGAL::Triangulation_2< Traits, Tds >::triangle, which only accepts Face_handles.Thanks.
- [cgal-discuss] Face_handle from face?, Jack Stalnaker, 11/25/2014
- Re: [cgal-discuss] Face_handle from face?, Chris Marsh, 11/25/2014
- Re: [cgal-discuss] Face_handle from face?, Jack Stalnaker, 11/25/2014
- Re: [cgal-discuss] Face_handle from face?, Sylvain Pion, 11/25/2014
