- To:
- Subject: Re: [cgal-discuss] Face_handle from face?
- Date: Tue, 25 Nov 2014 12:04:49 -0800
I can think of 2 ways.
First is to use Triangulation_data_structure::Face_range::s_iterator_to() similarly to what I wrote here :
Second is to go to a neighboring face and back : pick f.neighbor(0), then look among its 3 neighbors Face_handles which one has the same address as f.
2014-11-25 11:13 GMT-08:00 Jack Stalnaker <>:
I can't use c++11 features right now, but I did find a workaround.I wanted to do this:CGAL::centroid(cdt.triangle(face));but that didn't work as described above. However, this works:CGAL::centroid(face.vertex(0)->point(), face.vertex(1)->point(), face.vertex(2)->point())which will suffice unless anyone knows a cleaner way.On Tue, Nov 25, 2014 at 1:00 PM, Chris Marsh <> wrote:Mmh sorry, I misunderstood. Why not wrap DoSomething() in a lambda that does the cast? Although that is predicated on C++11 compiler features, which may be a no-go.On Tue, Nov 25, 2014 at 12:55 PM, Jack Stalnaker <> wrote:That works well for a for loop, but not for an STL algorithm like for_each like this:std::for_each(cdt.finite_faces_begin(), cdt.finite_faces_end(), DoSomething())where DoSomething is a functor. DoSomething gets *fit instead of fit, which is a face. I'd like to call cdt.triangle, but that only accepts Face_handles.On Tue, Nov 25, 2014 at 12:45 PM, Chris Marsh <> wrote:I do this:for (Delaunay::Finite_faces_iterator fit = this->finite_faces_begin();fit != this->finite_faces_end(); ++fit){Delaunay::Face_handle face = fit;Where Delaunay is justtypedef CGAL::Delaunay_triangulation_2<Gt, Tds> Delaunay; //specify a delauany triangulationCheersChrisOn Tue, Nov 25, 2014 at 12:41 PM, Jack Stalnaker <> wrote:How do I get a Face_handle from a face? If I use a finite_faces_iterator in an STL algorithm, it dereferences the iterator to a face, but I'd like to use Triangle CGAL::Triangulation_2< Traits, Tds >::triangle, which only accepts Face_handles.Thanks.
- [cgal-discuss] Face_handle from face?, Jack Stalnaker, 11/25/2014
- Re: [cgal-discuss] Face_handle from face?, Chris Marsh, 11/25/2014
- Re: [cgal-discuss] Face_handle from face?, Jack Stalnaker, 11/25/2014
- Re: [cgal-discuss] Face_handle from face?, Sylvain Pion, 11/25/2014
