cgal-discuss - Re: [cgal-discuss] Extract manifold Polyhedron_3 from Triangulation_3
  • To:
  • Subject: Re: [cgal-discuss] Extract manifold Polyhedron_3 from Triangulation_3
  • Date: Wed, 03 Dec 2014 15:39:02 +0100
Le 03/12/2014 15:31, Per Zetterlund a écrit :
To split the non-manifold vertices to get
a manifold, closed mesh is pretty easy.
But to split the non-manifold edges and
still have a closed mesh is hairier. But
perhaps I just haven't figured it out yet.
/Per
Hi Per,
Another possibility, convert the Triangulation_3 into a 3D linear cell complex (see CGAL::import_from_triangulation_3 [1]), then remove all the faces (using remove_cell<2>(lcc, d) [2]) of the LCC that do not belong to the boundary (to test if a dart d of a face belongs to the boundary, just use lcc.is_free<3>(d) [3]).
Guillaume
[1] http://doc.cgal.org/latest/Linear_cell_complex/group__PkgLinearCellComplexConstructions.html#ga7e8cde514b93c3441a4df2bc09c24068
[2] http://doc.cgal.org/latest/Combinatorial_map/group__PkgCombinatorialMapsOperations.html#gab70174b3358188a92dd3a0a054d02e42
[3] http://doc.cgal.org/latest/Combinatorial_map/classCombinatorialMap.html#acde359e3f68495a16b1eb615c23b6615
On Wed, Dec 3, 2014 at 2:38 PM, Sebastien Loriot (GeometryFactory)
wrote:
On 12/03/2014 02:23 PM, Per Zetterlund wrote:
As far as I understand, it can extract
a manifold Polyhedron as long as the the
surface embedded in the triangulation
actually is manifold. It does not in any
way enforce or aid in the process of making
the surface manifold, right?
Right.
When I try it I get lots of errors such as
CGAL::Polyhedron_incremental_builder_3<HDS>::
add_vertex_to_facet(): input error: disconnected facet complexes at vertex
352:
involved facets are: 1815 1814 1813 (closed cycle) and.
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: check_protocoll == 1
File: /usr/local/include/CGAL/Polyhedron_incremental_builder_3.h
Line: 225
Aborted (core dumped)
I guess that is because the embedded surface
was not manifold.
Most probably.
A simple hack is to duplicate the non-manifold vertices.
Sebastien.
/Per
On Tue, Dec 2, 2014 at 1:32 PM, Sebastien Loriot (GeometryFactory)
wrote:
On 11/24/2014 09:10 AM, Per Zetterlund wrote:
Hi all,
This is an issue I've run into several times
in different applications. Say that I have a
Triangulation_3 and I do a binary labelling of
the cells. Then I want to extract the interface
surface between the labels as a manifold
Polyhedron_3. Often it happens that that the
topology of the actual triangle faces in the
triangulation is not manifold. Are there any
routines in CGAL to extract a manifold surface
from a triangulation that (in some sense) is
close to the true interface surface?
There is nothing working out-of-the-box but looking
at the file CGAL/IO/Complex_2_in_triangulation_3_polyhedron_builder.h
should give you ideas of how a manifold surface mesh is extracted
from a 3D triangulation.
Sebastien.
Any ideas?
/Per
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
Attachment: smime.p7s
Description: Signature cryptographique S/MIME
