- To:
- Subject: Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2
- Date: Wed, 03 Dec 2014 15:45:33 +0100
Ok - thanks for a quick answer, spared me for trying in vain!
But the boolean operations takes generalized polygons ?
Many regards
Belhage
On Wed, 2014-12-03 at 12:46 +0200, Efi Fogel wrote:
> I'm afraid not.
> The input is restricted to a "standard" polygon (or polygon with
> holes), which can be represented by a sequence (or sequences if it has
> holes) of points for example.
> The output is what we call a generalized polygon (or a generalized
> polygon with wholes.) A generalized polygon must be represented by a
> sequence (or sequences if it has holes) of curves.
> Computing the Minkowski sum or even the offset of a generalized
> polygon, I think, is much more complicated.
> ____ _ ____ _
> /_____/_) o /__________ __ //
> (____ ( ( ( (_/ (_/-(-'_(/
> _/
> On Mon, Dec 1, 2014 at 10:42 PM, Lars Ole Belhage
> wrote:
> Hello,
> Running the many of the small test programs has convinced me
> of the
> versatility and elegance of the CGAL.
> Now, I'm trying to find a way to run the output of
> offset_polygon_2 into
> another offset_polygon_2. But after browsing documentation,
> I'm getting
> a little worried - can the "offset" algorithms work with
> polygons with
> arcs (or splines) in them ?
> If "yes", I will dig deeper and get the right traits to my
> data (but an
> simple extension of the the Minkowski_sum_2/exact_offset.cpp
> to do the
> sum several times, would of course be of great help)
> If "no", well...
> Great Salutions
> Belhage
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] offset_polygon_2 upon offset_polygon_2, Lars Ole Belhage, 12/01/2014
- Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2, Efi Fogel, 12/03/2014
- Re: [cgal-discuss] offset_polygon_2 upon offset_polygon_2, Lars Ole Belhage, 12/03/2014
