- To: "" <>
- Subject: [cgal-discuss] Reading in volume mesh with surfaces
- Date: Tue, 06 Jan 2015 07:10:40 +0000
Hi,
I have a set of volumetric mesh data with surface boundaries already defined, just like the typical example in the 3D mesh generation. Specifically, I have a set of tetrahedrons representing the volume, and facets of the tets are defined by surface ID, (ID1, ID2). However, this is data generated outside of CGAL, and I would like to read them in to a CGAL::Mesh_complex_3_in_triangulation_3<> data structure for further processing. Would there already be functions to do this with some standard file formats?
Thanks,
Frankie
- [cgal-discuss] Reading in volume mesh with surfaces, Shiu Fai Li, 01/06/2015
- Re: [cgal-discuss] Reading in volume mesh with surfaces, Laurent Rineau (CGAL/GeometryFactory), 01/06/2015
