- To:
- Subject: Re: [cgal-discuss] Reading in volume mesh with surfaces
- Date: Tue, 06 Jan 2015 11:19:16 +0100
Le Tuesday 06 January 2015 07:10:40 Shiu Fai Li a écrit :
> Hi,
> I have a set of volumetric mesh data with surface boundaries already
> defined, just like the typical example in the 3D mesh generation.
> Specifically, I have a set of tetrahedrons representing the volume, and
> facets of the tets are defined by surface ID, (ID1, ID2). However, this is
> data generated outside of CGAL, and I would like to read them in to
> a CGAL::Mesh_complex_3_in_triangulation_3<> data structure for further
> processing. Would there already be functions to do this with some standard
> file formats?
Hi. I am sorry but there is probably no chance that you can load your set of
tetrahedrons in a CGAL::Mesh_complex_3_in_triangulation_3. That CGAL data
structure needs the tetrahedrization to have only Delaunay tetrahedrons, and
you existing mesh is probably not a Delaunay mesh.
Laurent Rineau, PhD
- [cgal-discuss] Reading in volume mesh with surfaces, Shiu Fai Li, 01/06/2015
- Re: [cgal-discuss] Reading in volume mesh with surfaces, Laurent Rineau (CGAL/GeometryFactory), 01/06/2015
