cgal-discuss - Re: [cgal-discuss] Nef3: Wrong normal vector reported, causes triangulator crash
  • To:
  • Subject: Re: [cgal-discuss] Nef3: Wrong normal vector reported, causes triangulator crash
  • Date: Fri, 9 Jan 2015 17:47:30 -0500
Hey,
An update: Replacing my tessellation code with the GLU tessellator solves all
stability issues.
However, as the GLU tessellator naively build triangle fans after
decomposition, it’s far from being delaunay, and it tends to introduce zero
triangles (collinear vertices), which do not pass CGAL’s Polyhedron_3
preconditions.
Now, If I could just bypass Polyhedron_3 altogether. Does anyone happen to
have an example of how to create a Nef polyhedron directly from e.g. OFF
without going through a Polyhedron_3 ?
-Marius
On Jan 6, 2015, at 22:41 PM, Marius Kintel
wrote:
> Hi again,
> After looking more carefully at the code, I see that I do pass
> CGAL::Exact_predicates_tag as a tag to the CDT. As far as I understand,
> this means that the CDT should be robust wrt. intersecting constraints.
> Does that mean that I found a bug in CDT? If so, I can provide a minimal
> test program which breaks a stand-alone CDT.
> -Marius
