- To:
- Subject: [cgal-discuss] Problem with boolean operations on Polygons.
- Date: Wed, 14 Jan 2015 01:11:24 -0800 (PST)
Hello,
I have inserted these lines in my Project :
/// Construct the two input polygons.
Polygon_2 P;
P.push_back (Point_2 (0, 0));
P.push_back (Point_2 (5, 0));
P.push_back (Point_2 (3.5, 1.5));
P.push_back (Point_2 (2.5, 0.5));
P.push_back (Point_2 (1.5, 1.5));
std::cout << "P = "; print_polygon (P);
Polygon_2 Q;
Q.push_back (Point_2 (0, 2));
Q.push_back (Point_2 (1.5, 0.5));
Q.push_back (Point_2 (2.5, 1.5));
Q.push_back (Point_2 (3.5, 0.5));
Q.push_back (Point_2 (5, 2));
std::cout << "Q = "; print_polygon (Q);
// Compute the difference of P and Q.
Pwh_list_2 intR;
Pwh_list_2::const_iterator it;
CGAL::difference (P, Q, std::back_inserter(intR));
std::cout << "The difference:" << std::endl;
for (it = intR.begin(); it != intR.end(); ++it) {
std::cout << "--> ";
print_polygon_with_holes (*it);
...and I get compiling error :
no match for 'operator=' (operand types are
'std::back_insert_iterator<std::list<CGAL::Polygon_with_holes_2<CGAL::Epick>
Any clue ?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-boolean-operations-on-Polygons-tp4660305.html
- [cgal-discuss] Problem with boolean operations on Polygons., gilou_66, 01/14/2015
- Re: [cgal-discuss] Problem with boolean operations on Polygons., Sebastien Loriot (GeometryFactory), 01/14/2015
- Re: [cgal-discuss] Problem with boolean operations on Polygons., gilou_66, 01/14/2015
- Re: [cgal-discuss] Problem with boolean operations on Polygons., Efi Fogel, 01/15/2015
- Re: [cgal-discuss] Problem with boolean operations on Polygons., gilou_66, 01/15/2015
- Re: [cgal-discuss] Problem with boolean operations on Polygons., Efi Fogel, 01/20/2015
