cgal-discuss - Re: [cgal-discuss] Problem with boolean operations on Polygons.
  • To:
  • Subject: Re: [cgal-discuss] Problem with boolean operations on Polygons.
  • Date: Tue, 20 Jan 2015 13:42:46 +0200
Hi Gilles,
I'm not sure from your answer whether you have tried to compile and run my simple program. As I've said, for me, on Windows 8.1, using MSVC 10, it works without a flaw. I expect it to work using your platform as well.
Efi
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On Thu, Jan 15, 2015 at 5:45 PM, gilou_66 <> wrote:
Hello Efi,
Thank you so much !
It was actualy a class made expecially to explain the problem.
-> CGAL version : 4.5
-> Complier mingw32, under Windows 7.0
My name is Gilles !
Voilà.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Problem-with-boolean-operations-on-Polygons-tp4660305p4660316.html
