cgal-discuss - Re: [cgal-discuss] TBB bug report(?)
  • To: <>
  • Subject: Re: [cgal-discuss] TBB bug report(?)
  • Date: Wed, 14 Jan 2015 17:52:06 +0100
  • Authentication-results: spf=pass (sender IP is 137.224.8.147) ;
  • Organization: Wageningen University
I commented out those lines and the compilation works now.
Bart
On 12/12/2014 11:02 AM, Laurent Rineau (CGAL/GeometryFactory) wrote:
Le jeudi 11 décembre 2014 23:54:52 Adam Getchell a écrit :
It looks like TBB 4.3 is incompatible with <iostream> and <CGAL/Timer.h> on
my platform.
There is indeed an incompatibility between the code of CGAL-4.5 and TBB-4.3.
Here’s the output if I comment out all instances of CGAL/Timer.h:
https://gist.github.com/acgetchell/385be42d249e20a9b78c
Here’s the output with CGAL/Timer.h:
https://gist.github.com/acgetchell/a097d232859c318ecf69
If you look at the error messages more deeply, you can see that in both cases the
error is triggered by <CGAL/Spatial_lock_grid_3.h>, line 629:
/usr/local/include/CGAL/Spatial_lock_grid_3.h:629:12: note: in instantiation of member
function 'std::__1::vector<tbb::recursive_mutex,
std::__1::allocator<tbb::recursive_mutex> >::resize' requested here
m_grid.resize(num_cells);
/usr/local/include/tbb/recursive_mutex.h:39:25: note: copy constructor of
'recursive_mutex' is implicitly deleted because base class
'internal::mutex_copy_deprecated_and_disabled' has a deleted copy constructor
class recursive_mutex : internal::mutex_copy_deprecated_and_disabled {
/usr/local/include/tbb/tbb_stddef.h:334:44: note: copy constructor of
'mutex_copy_deprecated_and_disabled' is implicitly deleted because base class
'tbb::internal::no_copy' has an inaccessible copy constructor
class mutex_copy_deprecated_and_disabled : no_copy {};
With TBB-4.3, can you please try to erase, or comment out, the following
specialization:
template <>
class Spatial_lock_grid_3<Tag_non_blocking_with_mutexes>
between lines 614 and 665 of <CGAL/Spatial_lock_grid_3.h>? That
specialization is actusally not used by CGAL, and it should fix the compilation
errors with TBB-4.3.
Bart Vermeulen
Wageningen University, Department of Environmental Sciences
Hydrology and Quantitative Water Management Group
Postal address: Postbus 47, 6700AA Wageningen,The Netherlands
Visiting address: Room 0.C027, Droevendaalsesteeg 3,6708PB Wageningen, The
Netherlands
Tel. +31-317-482765 Fax +31-317-419000
email:
