- To:
- Subject: Re: [cgal-discuss] do_intersect for Polygon_2.
- Date: Tue, 20 Jan 2015 17:03:26 +0200
Hi Gilles,
You are quoting the manual of the do_intersect() free function of the kernel. Indeed, this function does not support polygons. Like all kernel functions (and functors) it operates on geometric objects of fixed sizes, which does not include polygons. ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Tue, Jan 20, 2015 at 4:13 PM, gilou_66 <> wrote:
Hello Efi,
Reading the CGAL docs, it says :
The types Type1 and Type2 can be any of the following:
Point_2<Kernel>
Line_2<Kernel>
Ray_2<Kernel>
Segment_2<Kernel>
Triangle_2<Kernel>
Iso_rectangle_2<Kernel>
Also, Type1 and Type2 can be both of type
Line_2<Kernel>
Circle_2<Kernel>
But I just tried with Polygon_2 type and it goes very well !
Have you an explanation ?
Gilles
View this message in context: http://cgal-discuss.949826.n4.nabble.com/do-intersect-for-Polygon-2-tp4660328p4660332.html
- [cgal-discuss] do_intersect for Polygon_2., gilou_66, 01/20/2015
- Re: [cgal-discuss] do_intersect for Polygon_2., Efi Fogel, 01/20/2015
- Re: [cgal-discuss] do_intersect for Polygon_2., gilou_66, 01/20/2015
