- To:
- Subject: Re: [cgal-discuss] Mesh Points on the Edge and Combining Polygons
- Date: Tue, 20 Jan 2015 17:06:23 +0200
Check out the 2D Regularized Boolean Operation package.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Tue, Jan 20, 2015 at 3:18 PM, Omer Ozturk <> wrote:
Hello everyone,
I have two questions;
1) I need to determine whether a mesh point is on the edges or inside a 2D
polygon. If the point is inside the polygon (not on the egdes), I need to
erase it. Is there a way to do this?
2) I have to combine two or more polygons to make a new polygon. When I was
working on my 3D module, there was a polyhedron corefinement property and I
need it in my 2D module too. Is it possible?
Thanks.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Mesh-Points-on-the-Edge-and-Combining-Polygons-tp4660331.html
- [cgal-discuss] Mesh Points on the Edge and Combining Polygons, Omer Ozturk, 01/20/2015
- Re: [cgal-discuss] Mesh Points on the Edge and Combining Polygons, Efi Fogel, 01/20/2015
