cgal-discuss - [cgal-discuss] Assertion failed: intersect Nef polyhedron with plane
  • To:
  • Subject: [cgal-discuss] Assertion failed: intersect Nef polyhedron with plane
  • Date: Tue, 20 Jan 2015 17:10:20 -0500
Hi all,
I’m trying to intersect a Nef polyhedron with a plane in order to get a 2D
cross section.
However, I frequently experience assertion errors when doing this, even
though my Nef polyhedrons appear to be simple and valid 2-manifolds:
CGAL::Assertion_exception: CGAL ERROR: assertion violation!
Expr: target(s1).vertex()==target(s2).vertex()
File:
/Users/kintel/code/OpenSCAD/libraries/install/include/CGAL/Nef_3/SNC_FM_decorator.h
Line: 218
As an example, I’ve attached a minimal test program which intersects an
object with the XY plane.
A failing .nef3 file can be found here:
http://files.openscad.org/projection.nef3.gz
FYI: The Nef polyhedron was created by importing an STL mesh into a
Polyhedron_3 and creating the Nef polyhedron from there.
I had expected this intersection to be numerically stable, but perhaps I’ve
slightly misunderstood the limitations of operations on Nef polyhedrons. Any
ideas?
Kind Regards,
-Marius
Attachment: projection.cpp
Description: Binary data
