- To:
- Subject: Re: [cgal-discuss] Assertion failed: intersect Nef polyhedron with plane
- Date: Fri, 23 Jan 2015 09:09:16 -0500
On Jan 23, 2015, at 02:30 AM, Sebastien Loriot (GeometryFactory)
wrote:
> There is a header CGAL/Polyhedron_slicer_3.h that is doing what you want
> but on a polyhedron. The code is not totally robust (in particular when you
> have coplanar facets in the plane) for now but the upcoming version will be
> (code is ready but we're in code freeze so it will be in 4.7).
> I can share the robust version of the code if needed.
That’s interesting - I’d be interested in testing it - I have lots of corner
cases :)
-Marius
- [cgal-discuss] Assertion failed: intersect Nef polyhedron with plane, Marius Kintel, 01/20/2015
- Re: [cgal-discuss] Assertion failed: intersect Nef polyhedron with plane, Sebastien Loriot (GeometryFactory), 01/23/2015
- Re: [cgal-discuss] Assertion failed: intersect Nef polyhedron with plane, Marius Kintel, 01/23/2015
