cgal-discuss - [cgal-discuss] Strange Gmpzf behavior?
  • To:
  • Subject: [cgal-discuss] Strange Gmpzf behavior?
  • Date: Fri, 23 Jan 2015 10:05:47 -0800
Hello all,
For this piece of code:
const long double tolerance{0.05};
CGAL::Gmpzf Bulk_action = S3_bulk_action(N1_TL, N3_31, N3_22,
    Alpha, K, Lambda);
  CGAL::Gmpzf Bulk_action_one = S3_bulk_action_alpha_one(N1_TL,
    N3_31, N3_22, K, Lambda);
  std::cout << (1.0-tolerance) << std::endl;
  CGAL::Gmpzf min(abs(Bulk_action_one*(1.0-tolerance)));
  std::cout << "(Gmpzf) min = " << min << std::endl;
  std::cout << (1.0+tolerance) << std::endl;
  CGAL::Gmpzf max = abs(Bulk_action_one*(1.0+tolerance));
  std::cout << "(Gmpzf) max = " << max << std::endl;
  ASSERT_THAT(abs(Bulk_action), AllOf(Ge(min), Le(max)))
    << "General Bulk action does not match Bulk action for alpha=1.";
In this file:
https://github.com/acgetchell/CDT-plusplus/blob/master/unittests/S3BulkActionTest.cpp
Gmpzf(1.0-tolerance) = 0, yet Gmpzf(1.0+tolerance) gives the normal value:
┌─[adam][Hapkido][±][master ][~/CDT-plusplus]
└─▪ ./build/unittests --gtest_filter=S3BulkAction.GeneralBulkActionE*
Note: Google Test filter = S3BulkAction.GeneralBulkActionE*
[==========] Running 1 test from 1 test case.
[----------] Global test environment set-up.
[----------] 1 test from S3BulkAction
[ RUN      ] S3BulkAction.GeneralBulkActionEquivalentToAlpha1BulkAction
Generating universe ...
Pass #1
Fixing foliation....
Pass #2
Pass #3
Pass #4
Classifying simplices....
Valid foliation: true
Delaunay triangulation has 97319 cells.
There are 30317 (3,1) simplices and 36366 (2,2) simplices and 30636 (1,3) simplices.
N1_SL = 45985
N1_TL = 66956
(Unsigned) N1_TL = 66956
(Unsigned) N3_31 = 60953
(Unsigned) N3_22 = 36366
(Long double) Alpha = 1
(Long double) K = 1.1
(Long double) Lambda = 2.2
result is -2.800688724949974576737072783301035236228214800450166604257791276251275672232602e483
result is -2.804983342973199104573080939525782360659232139621072320577600041374197112669744e483
0.95
(Gmpzf) min = 0
1.05
(Gmpzf) max = 28049.8
[       OK ] S3BulkAction.GeneralBulkActionEquivalentToAlpha1BulkAction (2086 ms)
[----------] 1 test from S3BulkAction (2086 ms total)
[----------] Global test environment tear-down
[==========] 1 test from 1 test case ran. (2086 ms total)
[  PASSED  ] 1 test.
Is this a bug, or am I misusing Gmpzf?
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
