cgal-discuss - Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error.
  • To: "" <>
  • Subject: Re: [cgal-discuss] Parallel Delaunay triangulation construction. Compilation error.
  • Date: Fri, 23 Jan 2015 19:46:44 +0300
  • Envelope-from:
23.01.2015, 19:28, "Laurent Rineau (CGAL/GeometryFactory)"
> That piece of code in Triangulation_3/parallel_insertion_in_delaunay_3.cpp
> can
> be compiled only if CGAL_LINKED_WITH_TBB is defined. If you do not use CGAL
> CMake script to create your build system or solution, then you must define
> that macro yourself.
Ok. That helped!
One little question:
Triangulation::Lock_data_structure locking_ds(
CGAL::Bbox_3(-1., -1., -1., 1., 1., 1.), 50);
What does number "50" mean in this example. I failed to find any
documentation about constructors of Lock_data_structure.
Thanks.
Ilya Palachev
