cgal-discuss - [cgal-discuss] 3D mesh generation on polyhedral domain, internal surfaces (or holes) missing
  • To:
  • Subject: [cgal-discuss] 3D mesh generation on polyhedral domain, internal surfaces (or holes) missing
  • Date: Wed, 28 Jan 2015 17:44:36 -0800 (PST)
Hi, all,
When I was mesh a 3D domain with 2 holes using CGAL, one hole missed in the
obtained mesh. I don't know why this happens? Has anyone encountered this
kind of problem? I will appreciate if you can share your experience with me.
My code is shown as below, and the input polygon as well as the generated
mesh can be found in the attachment.
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::FT FT;
typedef K::Point_3 Point;
typedef FT (Function)(const Point&);
typedef CGAL::Polyhedron_3<K> Polyhedron;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, K> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3
C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3
Mesh_criteria;
int main()
Polyhedron polyhedron;
std::ifstream input("F:\\data\\CAD_Polygon.off");
input >> polyhedron;
// Create domain
Mesh_domain domain(polyhedron);
Mesh_criteria criteria(facet_size = 0.001,facet_distance=0.0001,cell_size
= 0.002);
// Mesh generation
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, no_perturb(),
no_exude());
// Output
std::ofstream medit_file("F:\\out.mesh");
c3t3.output_to_medit(medit_file);
medit_file.close();
return 0;
Best wishes,
Yaohui
<http://cgal-discuss.949826.n4.nabble.com/file/n4660365/Polygon.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4660365/Mesh.png>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-mesh-generation-on-polyhedral-domain-internal-surfaces-or-holes-missing-tp4660365.html
