Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex
- To:
- Subject: Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex
- Date: Tue, 3 Feb 2015 01:22:07 -0800 (PST)
Guillaume Damiand wrote
> Which version of cgal ?
> Do you have a minimal example ?
> Are you sure this error comes from the call of sew3_same_facets() ?
> Because this function is called in the linear cell complex which
> compiles on many different os and compilers...
Compilation error is fixed now. I was passing /void/ as template arguments
for /onSplit/ and /onMerge/ functors in /CGAL::Cell_attribute_with_point/
class which I should have left uninitialized as they are initialized as
/Null functors/ by default.
But I would like to know whether we need to write functor for merge(which
may happen during /sew3_same_facets()/) in the case when both vertices have
same information unlike the example given here
<http://doc.cgal.org/latest/Linear_cell_complex/Linear_cell_complex_2linear_cell_complex_3_with_colored_vertices_8cpp-example.html>
where merging vertices may have different color information(thus requiring
averaging)?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Implementing-tetrahedral-mesh-with-cavities-using-Linear-cell-complex-tp4659399p4660385.html
- Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex, Pranav, 02/03/2015
- Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex, Guillaume Damiand, 02/03/2015
