Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex
- To:
- Subject: Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex
- Date: Mon, 2 Feb 2015 21:20:03 -0800 (PST)
Guillaume Damiand wrote
> If you are able to compute these sets, and if they have the good
> geometry (i.e. the boundaries of the sets fill the cavities), you can
> call the undocumented method sew3_same_facets which will do the job
> (i.e. identify all the pairs of faces having the same geometry).
I tried using sew3_same_facets() function but I am getting following
compilation error:
*/usr/local/include/CGAL/internal/Combinatorial_map_internal_functors.h:96:5:
error: void value not ignored as it ought to be
I have called this function as:
*lcc.sew3_same_facets()*
after inserting some tetrahedra into the existing linear cell complex /lcc/
using /make_tetrahedron/ function.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Implementing-tetrahedral-mesh-with-cavities-using-Linear-cell-complex-tp4659399p4660383.html
- Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex, Pranav, 02/03/2015
- Re: [cgal-discuss] Implementing tetrahedral mesh with cavities using Linear cell complex, Guillaume Damiand, 02/03/2015
