cgal-discuss - Re: [cgal-discuss] Integer overflow for large images:
  • To:
  • Subject: Re: [cgal-discuss] Integer overflow for large images:
  • Date: Tue, 3 Feb 2015 13:49:28 +0100
Hi,
Has the official version fixing this bug already been released?
Thanks
Dominik
2014-12-08 17:47 GMT+01:00 Jane Tournois
> Dear Bryn,
> we have fixed the bug you pointed out. The fix will be available in the next
> public release of CGAL.
> Thanks again.
> Best regards,
> Jane.
> Le 20/10/2014 08:57, Bryn Lloyd a écrit :
>> Dear Jane
>> Thanks, Bryn
>> On 10/17/2014 8:55 AM, Jane Tournois wrote:
>>> Dear Bryn,
>>> thanks for the patch you suggested.
>>> I will take care of this and keep you informed of its integration to
>>> CGAL.
>>> Best regards,
>>> Jane.
>>> Le 14/10/2014 09:38, Bryn Lloyd a écrit :
>>>> Dear CGAL developers
>>>> I would like to submit a patch for a problem which occurs when
>>>> generating a 3D mesh from very large images. The detailed information is
>>>> below:
>>>> OS, compiler:
>>>> - Windows 7 & 8, Visual Studio 2012
>>>> Build options:
>>>> - Configured using cmake for VS 2012, without GMP, without ZLIB
>>>> Description of the problem:
>>>> - Generating meshes from very large image (approx. 4e9 voxels) was not
>>>> working as expected. Sometimes one half of the image was meshed
>>>> correctly,
>>>> but strange things were happening to the other half.
>>>> Kernel (3D Mesh Generation from images/label fields):
>>>> - I was using an old version of CGAL (3.8), however, looking at the
>>>> newest version I can see that issue has not been fixed.
>>>> Solution:
>>>> - After debugging a bit, I found that the function
>>>> 'Image_3::labellized_trilinear_interpolation' was using 'unsigned int'
>>>> instead of e.g. 'std::uint64_t' or size_t. This causes an integer
>>>> overflow,
>>>> which breaks mesh generation.
>>>> Changing the code in Image_3.h and Image_to_labeled_function_wrapper.h
>>>> to use size_t fixed the issue.
>>>> I attached a patch.
>>>> Best regards
>>>> Bryn
> Jane Tournois, PhD
> R&D Engineer at GeometryFactory
> http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
