- To:
- Subject: Re: [cgal-discuss] optimal_convex_partition_2()
- Date: Tue, 3 Feb 2015 06:04:03 -0800 (PST)
here is the code
while(getline(lire,s))
Polygon_2 polygon;
if(s.find("Region")!=0)continue;
getline(lire,s);
std::stringstream ss;
ss<<s;
ss>>n;
for(int i = 0 ; i < n ; i++)
std::stringstream ss1;
getline(lire,s);
ss1<<s;
ss1>>x>>y;
lpc.push_back(K::Point_2(x,y));
llp.push_back(K::Point_2(x,y));
polygon.push_back(K::Point_2(x,y));
CGAL::optimal_convex_partition_2(polygon.vertices_begin(),
polygon.vertices_end(),
std::back_inserter(partition_polys),
partition);
lc.push_back(llp);
llp.clear();
the debugger is stopping here: Matrix<Partition_opt_cvx_edge> edges(polygon.size(), polygon.size());
in partition_optimal_convex_2h
2015-02-03 11:06 GMT+01:00 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]>:
On 02/02/2015 04:28 PM, tfern90 wrote:Without a minimal example showing a pb, we cannot really help.
> Hello,
> here is my polygon:
> <http://cgal-discuss.949826.n4.nabble.com/file/n4660381/Capture.jpg>
> it as 16 vertices, ans it's a simple polygon.
> CGAL::optimal_convex_partition_2(..) does not function correctly.
Sebastien
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/optimal-convex-partition-2-tp4660381.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/optimal-convex-partition-2-tp4660381p4660386.html
View this message in context: Re: optimal_convex_partition_2()
- [cgal-discuss] optimal_convex_partition_2(), tfern90, 02/02/2015
- Re: [cgal-discuss] optimal_convex_partition_2(), Sebastien Loriot (GeometryFactory), 02/03/2015
- Re: [cgal-discuss] optimal_convex_partition_2(), tfern90, 02/03/2015
- Re: [cgal-discuss] optimal_convex_partition_2(), Sebastien Loriot (GeometryFactory), 02/13/2015
- [cgal-discuss] CAGL::To_double, Yuetong Luo, 02/04/2015
- Re: [cgal-discuss] CAGL::To_double, Sebastien Loriot (GeometryFactory), 02/04/2015
