- To:
- Subject: Re: [cgal-discuss] Surface Mesh
- Date: Fri, 13 Feb 2015 12:47:19 +0100
Le Friday 13 February 2015 03:31:21 Omer Ozturk a écrit :
> Hello,
> I'm using CGAL to make surface mesh but for some objects the result is
> corrupted. For example, there is no problem when I generate surface mesh for
> a cube, but when I generate it for a polyhedron that has different edge
> lengths, it looks like in the attached image. What am I doing wrong?
> Thanks.
> <http://cgal-discuss.949826.n4.nabble.com/file/n4660445/Corrupted.png>
The Surface Mesh Generator of CGAL does not deal with object with sharp
features. You can try to use the 3D Mesh Generator from CGAL, with special
mesh criteria that allow any shape and size of the cells in the domain. That
will be almost equivalent to the Surface Mesh Generator.
Laurent Rineau, PhD
- [cgal-discuss] Surface Mesh, Omer Ozturk, 02/13/2015
- Re: [cgal-discuss] Surface Mesh, Laurent Rineau (CGAL/GeometryFactory), 02/13/2015
- Re: [cgal-discuss] Surface Mesh, Omer Ozturk, 02/13/2015
