cgal-discuss - Re: [cgal-discuss] Surface Mesh
  • To:
  • Subject: Re: [cgal-discuss] Surface Mesh
  • Date: Fri, 13 Feb 2015 17:40:03 +0100
Le Friday 13 February 2015 07:06:32 Omer Ozturk a écrit :
> Thanks but when edge lengths are same, the result is fine. By the way I'm
> using Remeshing plugin in the Polyhedron demo. Here is the screen capture;
> <http://cgal-discuss.949826.n4.nabble.com/file/n4660447/CubeMesh.png>
The Surface Mesh Generator (used by the remeshing plugin) does not try to
protect sharp features. However, on the cube, *by change*, the edges are
meshes correctly. But that is not a property that is enforced.
Laurent Rineau, PhD
