cgal-discuss - [cgal-discuss] Straight Skeleton: Subsequent collinear points
  • To:
  • Subject: [cgal-discuss] Straight Skeleton: Subsequent collinear points
  • Date: Wed, 18 Feb 2015 10:41:58 +0100
Dear CGAL-Team,
I am working with your Straight Skeleton implementation. I encountered
a problem with the following polygon:
polygon[(320, 1120),(-141.55499021951055738,
1658.4808219227620611),(-1115.9820207544369168,
1835.6551586833445526),(760, 520),(800, 560),(840, 600),(800,
640),(400, 1040)]
I try to generate the straight skeleton with the following call:
typedef CGAL::Cartesian<CGAL::Gmpq> Kernel;
Kernel c;
CGAL::create_interior_straight_skeleton_2<CGAL::Polygon_2<Kernel>>(polygon,
c);
The algorithm aborts after a few seconds with the following assertion
violated.
/usr/include/boost/smart_ptr/shared_ptr.hpp:646: typename
boost::detail::sp_dereference<T>::type
boost::shared_ptr<T>::operator*() const [with T =
CGAL::Straight_skeleton_2<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::Straight_skeleton_items_2, std::allocator<int> >; typename
boost::detail::sp_dereference<T>::type =
CGAL::Straight_skeleton_items_2, std::allocator<int> >&]: Assertion
`px != 0' failed.
The subsequent collinear points seems to be troubling. Removing the
collinear points yields to a successful computation. As far as I see,
collinear points are not considered a degenerated case
(http://doc.cgal.org/latest/Straight_skeleton_2/index.html, 1.1 2D
Contours). So, I suppose it is bug?
Kind regards
Marcel
System Details:
OpenSuse 13.2 (Harlequin) x86_64
Intel (R) Xeon (R) CPU E5430 @ 2.66Ghz
GCC 4.8.3, flags: -frounding-math -std=c++11 -O0 -g -gdwarf-3 -W -Wall
-Wextra -pedantic -fopenmp
CGAL 4.5.2 - compiled without any additional flags
