- To:
- Subject: Re: [cgal-discuss] Dual edge of Apollonius Graph
- Date: Thu, 19 Feb 2015 19:34:39 -0800 (PST)
Sebastien Loriot (GeometryFactory) wrote
> On 02/19/2015 12:59 PM, Olivier Devillers wrote:
>> Le 19/02/15 11:18, Narusaki a écrit :
>>> multiply the sites
>>> by 10^0 and 10^1 separately:
>>> <http://cgal-discuss.949826.n4.nabble.com/file/n4660484/p1.png>
>>> <http://cgal-discuss.949826.n4.nabble.com/file/n4660484/p2.png>
>> Just guessing:
>> For infinite edges of the diagram, you have to crop them somewhere.
>> Probably the cropping window is not well defined and, depending
>> on your scaling factor you have only few segements of the discretixzation
>> in your visualizing window.
>> This will disappear for finite edges of the diagram,
>> when you put more disks.
> After having a look at the point set, I think Olivier is right.
> The bbox is x (-19999.2, 11488.3), y (-16372.4, 211.311)
> Sebastien.
> Thanks Olivier and Sebastien, I get what you meant and will give it a try.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Dual-edge-of-Apollonius-Graph-tp4660456p4660500.html
- [cgal-discuss] Dual edge of Apollonius Graph, Narusaki, 02/18/2015
- Re: [cgal-discuss] Dual edge of Apollonius Graph, Sebastien Loriot (GeometryFactory), 02/19/2015
- Re: [cgal-discuss] Dual edge of Apollonius Graph, Narusaki, 02/19/2015
- Re: [cgal-discuss] Dual edge of Apollonius Graph, Olivier Devillers, 02/19/2015
- Re: [cgal-discuss] Dual edge of Apollonius Graph, Narusaki, 02/20/2015
