cgal-discuss - Re: [cgal-discuss] Fast search of local positive quadruples on the sphere
  • To:
  • Subject: Re: [cgal-discuss] Fast search of local positive quadruples on the sphere
  • Date: Wed, 18 Feb 2015 17:10:37 +0100
Le 18/02/15 16:57, Илья Палачев a écrit :
Hi,
If this is not the right place this question, please redirect me :)
I'm solving some computational problem, and there is a question for which I have not have enough experience in computational geometry. Maybe you can advise some methods that are already implemented in CGAL for that?
Here is the problem.
Let U = {u_1, u_2, ..., u_n} be the finite set of points on the unit sphere in R^3.
If I rephrase your problem in the plane:
Find all quadruple (u_i,u_j,u_k,u_l) such that u_i is the only point of U innside triangle u_j u_k u_l.
Rq: You have Theta(n^3) solutions
Upper bound:
you have n^3 choices for the triangle, then there is no choice for the point inside it.
Lower bound
--- n/3 points on segment [(0,-10),(1,-10)] (possible u_j)
--- n/3 points on segment [(0,10),(1,10)] (possible u_k)
--- n/3 points on segment [(-10,-1),(-10,1)] (possible u_l)
--- the origin (possible u_i)
