- To: "" <>
- Subject: Re: [cgal-discuss] Fast search of local positive quadruples on the sphere
- Date: Wed, 18 Feb 2015 21:04:49 +0300
- Envelope-from:
18.02.2015, 20:49, "Илья Палачев" <>:
It shows that in their case there was 3000 local tests for 600 directions.Maybe I'm misunderstanding their definition of "local positive cone tests":
Oh. Sorry. I've missed that the graph has label "ratio":
The figure shows the ratio of the total number oftests, as required in Theorem 3 or Corollary 1, tothe corresponding number of local tests, as defined inTheorem 4, as a function of the total number of sam-ple directions chosen.
It means that there was something like Theta(n^2) or Theta(n^2 log n) in that case.
You're right.
But is there any algorithm of complexity = Theta(n^2) of Theta(n^2 log n) for this case?
It is much better than Theta(n^4) for testing of all quadruples.
What do you think?
- [cgal-discuss] Fast search of local positive quadruples on the sphere, Илья Палачев, 02/18/2015
- Re: [cgal-discuss] Fast search of local positive quadruples on the sphere, Olivier Devillers, 02/18/2015
- Re: [cgal-discuss] Fast search of local positive quadruples on the sphere, thierry Fernandez, 02/18/2015
- Re: [cgal-discuss] Fast search of local positive quadruples on the sphere, Илья Палачев, 02/18/2015
- Re: [cgal-discuss] Fast search of local positive quadruples on the sphere, Olivier Devillers, 02/19/2015
