cgal-discuss - Re: [cgal-discuss] Dual edge of Apollonius Graph
  • To:
  • Subject: Re: [cgal-discuss] Dual edge of Apollonius Graph
  • Date: Thu, 19 Feb 2015 12:04:38 +0100
On 02/19/2015 11:52 AM, Narusaki wrote:
Sebastien Loriot (GeometryFactory) wrote
On 02/19/2015 11:18 AM, Narusaki wrote:
Hi Sebastien,
Thank you for the reply. I've found the bug for the extra ray -- it's
because I thought the pleft/pright of the hyperbola mean the left/right
branch, but it turns out it means the left/right part of the branch
according to the axis.
Now it only leaves me with the problem of the shape of the hyperbola. I
gradually multiply each site (x, y, z) by 10^0, 10^1, ..., etc. and the
hyperbola seems to be more and more smooth. I've checked the points
generated by the function you've mentioned, and it's indeed about 100
points
Where are these points then?
Sebastien.
(with an extra one) for whether there is a multiplier for each site or
not.
For example, the following two pics are corresponding to multiply the
sites
by 10^0 and 10^1 separately:
&lt;http://cgal-discuss.949826.n4.nabble.com/file/n4660484/p1.png&gt;
&lt;http://cgal-discuss.949826.n4.nabble.com/file/n4660484/p2.png&gt;
It seems that the first one is approximated by two line segment and the
the
second one is approximated by four. I've tried to use the kernel you
mentioned but that doesn't help, and as I've mentioned above, the
generated
points number seems to be no problem.
So what the problem could be now?
Well just on the line segments in the former pics, I guess. Since I'm
rendering the hyperbola by each of its small line segments myself, I think
this shouldn't be the problem.
Could you add a cout in the point generation function to print the
point into a file and post it here? I just want to check.
Sebastien.
And as I'm reading the Hyperbola_2.h file, I found there're two versions
of generate_points() method, and in the one with the "_qt" suffix (which I
think it may serve for the rendering in the qt GUI framework), I saw the
STEP variable is set according to the size of the window, which is
obviously skipped in the raw generate_points() method. Could this be the
problem?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Dual-edge-of-Apollonius-Graph-tp4660456p4660484.html
http://cgal-discuss.949826.n4.nabble.com/Dual-edge-of-Apollonius-Graph-tp4660456p4660490.html
