Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks
- To:
- Subject: Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks
- Date: Thu, 26 Feb 2015 08:54:05 +0100
Le 26/02/2015 07:00, Pranav a écrit :
Guillaume Damiand wrote
I cannot compile your code due to the #include "../rply/rply.h"I have written another small code which does not have that dependency. I
have posted it here
<https://gist.github.com/pranavkantgaur/740a086f06248265a63d#file-autocubelcc-cpp>
. And I am now sewing the 2-cells outside the loop as you suggested.
But now I find that number of dart pairs which can be 2-sewed are different
inside and outside the loop. You can see that in the output print messages.
Could you please suggest why is it so?
Three things:
1) You need to add
if (!cubeLCC.is_marked(segIter2, sewedMark))// not sewed till now
inside the 4th loop.
2) You need to add a test on the geometry in order to sew<2> edges having same extremities.
3) You can simplify your code. Instead of iterating through one dart per 2-cell, then iterating through all the darts of this 2-cell, you can simply iterate through all the darts of the map (both for segIter1 and segIter2).
Guilllaume
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Combinatorial-Maps-Getting-runtime-assertation-errors-while-using-marks-tp4660525p4660531.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
smime.p7s
Description: Signature cryptographique S/MIME
- [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Pranav, 02/25/2015
- Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Guillaume Damiand, 02/25/2015
- Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Pranav, 02/26/2015
- Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Guillaume Damiand, 02/26/2015
