Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks
- To:
- Subject: Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks
- Date: Thu, 26 Feb 2015 02:04:28 -0800 (PST)
Guillaume Damiand wrote
> 1) You need to add
> if (!cubeLCC.is_marked(segIter2, sewedMark))// not sewed till now
> inside the 4th loop.
> 2) You need to add a test on the geometry in order to sew<2> edges
> having same extremities.
> 3) You can simplify your code. Instead of iterating through one dart per
> 2-cell, then iterating through all the darts of this 2-cell, you can
> simply iterate through all the darts of the map (both for segIter1 and
> segIter2).
Applied all your suggestions and now it is working
<https://gist.github.com/pranavkantgaur/740a086f06248265a63d#file-autocubelcc-cpp>
. Thanks!!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Combinatorial-Maps-Getting-runtime-assertation-errors-while-using-marks-tp4660525p4660533.html
- [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Pranav, 02/25/2015
- Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Guillaume Damiand, 02/25/2015
- Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Pranav, 02/26/2015
- Re: [cgal-discuss] Combinatorial Maps: Getting runtime assertation errors while using marks, Guillaume Damiand, 02/26/2015
