- To:
- Subject: Re: [cgal-discuss] Setting debug mode, errors in debug but not release
- Date: Thu, 5 Mar 2015 11:23:42 -0800
┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ brew info cgal
cgal: stable 4.5.2 (bottled)
/usr/local/Cellar/cgal/4.5.2 (2731 files, 33M) *
Built from source with: --c++11, --imaging, --with-eigen3, --with-lapack
From: https://github.com/Homebrew/homebrew/blob/master/Library/Formula/cgal.rb
==> Dependencies
Build: cmake ✔
Required: boost ✔, gmp ✔, mpfr ✔
==> Options
--c++11
Build using C++11 mode
--imaging
Build ImageIO and QT compoments of CGAL
--with-eigen3
Build with Eigen3 support
--with-lapack
Build with LAPACK support
What's your CGAL_DIR? Did you build CGAL from source with CMAKE_BUILD_TYPE=Debug?--AlexOn Thu, Mar 5, 2015 at 2:10 AM, Adam Getchell <> wrote:Hello all,No matter that I set -DCMAKE_BUILD_TYPE=Debug, I always get a Release build:┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ mkdir build
└─▪ cd build
┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus/build]
└─▪ cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug ..
-- The C compiler identification is AppleClang 6.0.0.6000056
-- The CXX compiler identification is AppleClang 6.0.0.6000056
-- Check for working C compiler using: Ninja
-- Check for working C compiler using: Ninja -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Ninja
-- Check for working CXX compiler using: Ninja -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib '
-- Targetting Ninja
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- Requested component: Core
-- Requested component: MPFR
-- Requested component: GMP
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version "3.2.4", minimum required is "3.1.0")
-- Found Intel TBB
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CDT-plusplus/build
According to the cmake list, one of CGALs find_package modules is setting the CMAKE_BUILD_TYPE, though I have been unable to verify this.The only workaround I've found is to build twice, e.g. the script scan-build.sh is:#! /bin/bashrm -rf build/mkdir buildcd buildcmake -G Ninja -DCMAKE_C_COMPILER=/usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/ccc-analyzer -DCMAKE_CXX_COMPILER=/usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/c++-analyzer ..cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug ../usr/local/opt/llvm/bin/scan-build -o $(pwd)/scanresults -v ninjaWhich results in:┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ ./scan-build.sh
-- Targetting Ninja
-- Using /usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/c++-analyzer compiler.
-- Found Intel TBB
-- Configuring done
-- Generating done
-- Build type: Debug
-- USING CXXFLAGS = ' -g'
-- Targetting Ninja
-- Found Intel TBB
-- Configuring done
-- Generating done
scan-build: Using '/usr/local/Cellar/llvm/3.5.1/bin/clang' for static analysis
scan-build: Emitting reports for this run to '/Users/adam/CDT-plusplus/build/scanresults/2015-03-05-020325-15162-1'.
[13/13] Linking CXX executable unittests
FAILED: : && /usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/c++-analyzer -g -Wl,-search_paths_first -Wl,-headerpad_max_install_names -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib CMakeFiles/unittests.dir/unittests/main.cpp.o CMakeFiles/unittests.dir/unittests/PointTest.cpp.o CMakeFiles/unittests.dir/unittests/S3BulkActionTest.cpp.o CMakeFiles/unittests.dir/unittests/S3ErgodicMovesTest.cpp.o CMakeFiles/unittests.dir/unittests/S3TetrahedronTest.cpp.o CMakeFiles/unittests.dir/unittests/SdTriangulationTest.cpp.o CMakeFiles/unittests.dir/unittests/SphereTest.cpp.o CMakeFiles/unittests.dir/unittests/Triangulated2SphereTest.cpp.o CMakeFiles/unittests.dir/unittests/VertexTest.cpp.o -o unittests -L/usr/local/Cellar/cgal/4.5.2/lib -L/Users/adam/gmock-1.7.0/lib/.libs -L/Users/adam/gmock-1.7.0/gtest/lib/.libs /usr/local/lib/libmpfr.dylib /usr/local/lib/libgmp.dylib /usr/local/Cellar/cgal/4.5.2/lib/libCGAL_Core.dylib /usr/local/Cellar/cgal/4.5.2/lib/libCGAL.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/lib/libboost_system-mt.dylib -lgmock -lgtest -lpthread -Wl,-rpath,/usr/local/Cellar/cgal/4.5.2/lib -Wl,-rpath,/Users/adam/gmock-1.7.0/lib/.libs -Wl,-rpath,/Users/adam/gmock-1.7.0/gtest/lib/.libs && :
Undefined symbols for architecture x86_64:
"tbb::task_group_context::init()", referenced from:
tbb::task_group_context::task_group_context(tbb::task_group_context::kind_type, unsigned long) in S3TetrahedronTest.cpp.o
"tbb::task_group_context::~task_group_context()", referenced from:
Plus a ton of errors about tbb. Full dump here:Thanks for any tips,--Adam Getchell"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
- [cgal-discuss] Setting debug mode, errors in debug but not release, Adam Getchell, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Alex Tsui, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Adam Getchell, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Qingnan Zhou, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Adam Getchell, 03/11/2015
