- To:
- Subject: Re: [cgal-discuss] Setting debug mode, errors in debug but not release
- Date: Thu, 5 Mar 2015 15:53:21 -0500
cmake -DCGAL_DONT_OVERRIDE_CMAKE_FLAGS=TRUE -DCMAKE_BUILD_TYPE=Debug ..
The homebrew script is set to compile in Release mode, and so it seems that it will switch your build type to Release regardless of what you set it. I tried building a test project in Release mode and linking to a CGAL built in Debug mode and it did the opposite - it was switched to Debug mode.Maybe try to fetch CGAL and build it yourself in Debug mode? Then export CGAL_DIR=/path/to/your/cgal and try rebuilding your project.--AlexOn Thu, Mar 5, 2015 at 11:23 AM, Adam Getchell <> wrote:No, I installed it via Homebrew:┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ brew info cgal
cgal: stable 4.5.2 (bottled)
/usr/local/Cellar/cgal/4.5.2 (2731 files, 33M) *
Built from source with: --c++11, --imaging, --with-eigen3, --with-lapack
From: https://github.com/Homebrew/homebrew/blob/master/Library/Formula/cgal.rb
==> Dependencies
Build: cmake ✔
Required: boost ✔, gmp ✔, mpfr ✔
==> Options
--c++11
Build using C++11 mode
--imaging
Build ImageIO and QT compoments of CGAL
--with-eigen3
Build with Eigen3 support
--with-lapack
Build with LAPACK support
On Thu, Mar 5, 2015 at 6:33 AM, Alex Tsui <> wrote:What's your CGAL_DIR? Did you build CGAL from source with CMAKE_BUILD_TYPE=Debug?--AlexOn Thu, Mar 5, 2015 at 2:10 AM, Adam Getchell <> wrote:Hello all,No matter that I set -DCMAKE_BUILD_TYPE=Debug, I always get a Release build:┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ mkdir build
└─▪ cd build
┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus/build]
└─▪ cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug ..
-- The C compiler identification is AppleClang 6.0.0.6000056
-- The CXX compiler identification is AppleClang 6.0.0.6000056
-- Check for working C compiler using: Ninja
-- Check for working C compiler using: Ninja -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Ninja
-- Check for working CXX compiler using: Ninja -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING EXEFLAGS = ' -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib '
-- Targetting Ninja
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- Requested component: Core
-- Requested component: MPFR
-- Requested component: GMP
-- Found Eigen3: /usr/local/include/eigen3 (found suitable version "3.2.4", minimum required is "3.1.0")
-- Found Intel TBB
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/adam/CDT-plusplus/build
According to the cmake list, one of CGALs find_package modules is setting the CMAKE_BUILD_TYPE, though I have been unable to verify this.The only workaround I've found is to build twice, e.g. the script scan-build.sh is:#! /bin/bashrm -rf build/mkdir buildcd buildcmake -G Ninja -DCMAKE_C_COMPILER=/usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/ccc-analyzer -DCMAKE_CXX_COMPILER=/usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/c++-analyzer ..cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug ../usr/local/opt/llvm/bin/scan-build -o $(pwd)/scanresults -v ninjaWhich results in:┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ ./scan-build.sh
-- Targetting Ninja
-- Using /usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/c++-analyzer compiler.
-- Found Intel TBB
-- Configuring done
-- Generating done
-- Build type: Debug
-- USING CXXFLAGS = ' -g'
-- Targetting Ninja
-- Found Intel TBB
-- Configuring done
-- Generating done
scan-build: Using '/usr/local/Cellar/llvm/3.5.1/bin/clang' for static analysis
scan-build: Emitting reports for this run to '/Users/adam/CDT-plusplus/build/scanresults/2015-03-05-020325-15162-1'.
[13/13] Linking CXX executable unittests
FAILED: : && /usr/local/Cellar/llvm/3.5.1/share/clang/tools/scan-build/c++-analyzer -g -Wl,-search_paths_first -Wl,-headerpad_max_install_names -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib CMakeFiles/unittests.dir/unittests/main.cpp.o CMakeFiles/unittests.dir/unittests/PointTest.cpp.o CMakeFiles/unittests.dir/unittests/S3BulkActionTest.cpp.o CMakeFiles/unittests.dir/unittests/S3ErgodicMovesTest.cpp.o CMakeFiles/unittests.dir/unittests/S3TetrahedronTest.cpp.o CMakeFiles/unittests.dir/unittests/SdTriangulationTest.cpp.o CMakeFiles/unittests.dir/unittests/SphereTest.cpp.o CMakeFiles/unittests.dir/unittests/Triangulated2SphereTest.cpp.o CMakeFiles/unittests.dir/unittests/VertexTest.cpp.o -o unittests -L/usr/local/Cellar/cgal/4.5.2/lib -L/Users/adam/gmock-1.7.0/lib/.libs -L/Users/adam/gmock-1.7.0/gtest/lib/.libs /usr/local/lib/libmpfr.dylib /usr/local/lib/libgmp.dylib /usr/local/Cellar/cgal/4.5.2/lib/libCGAL_Core.dylib /usr/local/Cellar/cgal/4.5.2/lib/libCGAL.dylib /usr/local/lib/libboost_thread-mt.dylib /usr/local/lib/libboost_system-mt.dylib -lgmock -lgtest -lpthread -Wl,-rpath,/usr/local/Cellar/cgal/4.5.2/lib -Wl,-rpath,/Users/adam/gmock-1.7.0/lib/.libs -Wl,-rpath,/Users/adam/gmock-1.7.0/gtest/lib/.libs && :
Undefined symbols for architecture x86_64:
"tbb::task_group_context::init()", referenced from:
tbb::task_group_context::task_group_context(tbb::task_group_context::kind_type, unsigned long) in S3TetrahedronTest.cpp.o
"tbb::task_group_context::~task_group_context()", referenced from:
Plus a ton of errors about tbb. Full dump here:Thanks for any tips,--Adam Getchell"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu--Adam Getchell"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
- [cgal-discuss] Setting debug mode, errors in debug but not release, Adam Getchell, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Alex Tsui, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Adam Getchell, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Qingnan Zhou, 03/05/2015
- Re: [cgal-discuss] Setting debug mode, errors in debug but not release, Adam Getchell, 03/11/2015
