- To:
- Subject: Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes
- Date: Tue, 05 May 2015 08:46:24 +0200
Sorry for not having answered before.
If you submit a pull request over https://github.com/CGAL/cgal
I can have a look at it to integrate it into CGAL.
Thanks,
Sebastien.
On 04/30/2015 09:45 PM, Vinicius Azevedo wrote:
Hey guys,
I've fixed the halfedgeDS_cut_component function to project the newly
created points on the cutting plane. To my surprise, that worked:
https://dl.dropboxusercontent.com/u/5919734/bunnyW1.png
https://dl.dropboxusercontent.com/u/5919734/bunnyw2.png
To do that, I've changed all Vertex() constructors from
to Vertex(pred.getPlane().projection(h->vertex()->point())). I've also
made some few adjustments on the polyhedron_cut_plane_3. If anyone is
interested I can post the full modified code.
Vinicius C. Azevedo.
On Thu, Apr 30, 2015 at 2:02 PM, Vinicius Azevedo
<mailto:>>
wrote:
Update:
The polyhedron_cut_plane_3 function
calls I_polyhedron_cut_component( poly, h, pred) routine. This
returns a set of invalid (uninitialized?) edges/faces that are
connected to the newly created cut border.
On Wed, Apr 29, 2015 at 2:48 PM, Vinicius Azevedo
<mailto:>>
wrote:
OK, so I think that I found a potential problem. Inside the
polyhedron_cut_plane_3 function we have:
Halfedge_handle start = h;
do {
h->vertex()->point() = construct_point( plane,
h->next()->opposite()->facet()->plane(),
h->opposite()->facet()->plane());
h = h->next();
} while ( h != start);
This function basically computes the intersection point from 3
planes: the cutting plane and the two planes that pass through
the current edge. The function construct_point is:
operator()( const Plane_3& p, const Plane_3& q, const Plane_3&
r) const {
Object obj = intersection( p, q);
Line_3 line;
if ( assign( line, obj)) {
obj = intersection( r, line);
Point_3 pt;
if ( assign( pt, obj)) {
return pt;
std::cerr << "ERROR: coplanar planes used for computing "
"intersecting point." << std::endl;
std::cerr << " Return ORIGIN. Don't trust result." <<
std::endl;
return ORIGIN;
This function tries to find the intersection point by
successively computing intersections between the planes. But
this algorithm *will fail if r and q planes are colinear. *That
means that if an edge has two colinear planes (e.g. a simple
plane), that algorithm will not work. So perhaps a /function
that better computes the intersection between a plane and an
edge has to be used to solved this problem/.
Any ideas? Is what I said correct?
Vinicius.
On Wed, Apr 29, 2015 at 11:15 AM, Vinicius Azevedo
<mailto:>>
wrote:
Sure, here's the code snippet: http://pastebin.com/C892FnCu
The interesting thing though is that the halfedge handle
that I'm passing is not one that directly crosses the
polyline intersection.If I try to pass an edge that is being
actually intersected by the polyline I get an assertion error.
On Wed, Apr 29, 2015 at 11:01 AM, Sebastien Loriot
(GeometryFactory)
<mailto:>>
wrote:
On 04/29/2015 04:56 PM, Vinicius Azevedo wrote:
I was confused by the cut/slice examples on the
Polyhedron demo. I
thought you was mentioning that, my bad. That's what
I was looking for,
thanks! I have some questions though on how to use
this function:
* What should I pass to the function as starting
halfedge? Is it an
edge returned by any_intersection?
I think so.
* Does this function add vertices from the
polyline that is generated
from the intersection of the polyhedron with
the plane? That's not
what I'm getting on my results
(https://dl.dropboxusercontent.com/u/5919734/bunnyCut1.png
https://dl.dropboxusercontent.com/u/5919734/bunnyCut2.png).
It only
cuts the mesh by following pre-existent
vertices. Also I'm having
the error "coplanar planes used for computing
the intersection
plane, Return ORIGIN, Don't trust the result".
I never used the function. Could you share your code so
that I can
give it a try?
Sebastien.
Thanks for your help so far!
On Tue, Apr 28, 2015 at 10:24 AM, Sebastien Loriot
(GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>
wrote:
On 04/28/2015 02:15 PM, Vinicius Azevedo wrote:
Hi Sebastian,
Thanks for your answer. I didn't expressed
myself so well. What
I want
is to actually cut the mesh into two
different independent parts
with a
given cut plane. In this video
https://www.youtube.com/watch?v=IOnk7PBv1AU and paper
http://www.math.ucla.edu/~jteran/papers/WJST14.pdf,
they present
some
techniques to do that robustly. I saw the
examples that you
mentioned,
and it seems that they only compute the
intersections of planes and
Polyhedrons, but don't actually split it
into different parts.
I believe this is what polyhedron_cut_plane_3.h
is doing. The comment
for this function is:
// Cuts the polyhedron `poly' at plane `plane'
starting at halfedge `h'.
// Traces the intersection curve of `plane'
with `poly' starting at `h',
// cuts `poly' along that intersection curve
and deletes the (connected)
// component on the negative side of the plane.
The hole created along
// the intersection curve is filled with a new
face containing the plane
// and the points in the vertices are computed.
Sebastien.
On Tue, Apr 28, 2015 at 1:48 AM, Sebastien
Loriot (GeometryFactory)
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>
wrote:
On 04/27/2015 04:31 PM, Vinicius
Azevedo wrote:
Hi all,
I would like to know if anyone has
a code snippet for
slicing/splitting/cutting
polyhedral meshes in two
different
parts with
arbitrary planes. I've seen some
old threads about it
(http://cgal-discuss.949826.n4.nabble.com/Slices-in-a-mesh-td951695.html),
but didn't find any code examples
so far.
Thanks!
The thread you mention is to compute
the intersection of a
polyhedron
with a plane which is one or several
polygons. There is a
non documented
functor that is doing this in
CGAL/Polyhedron_slicer_3.h
A better and documented version will
be included in CGAL 4.8
In your case, it seems you want the
intersection of a
polyhedron with
a halfspace.
There is another documented function
'CGAL::polyhedron_cut_plane_3'
I never used that is defined in
CGAL/polyhedron_cut_plane_3.h
that should be doing what you want.
Sebastien.
You are currently subscribed to
cgal-discuss.
To unsubscribe or access the archives,
go to
- Re: [cgal-discuss] Slicing/splitting/cutting polyhedral meshes, Sebastien Loriot (GeometryFactory), 05/05/2015
