cgal-discuss - Re: [cgal-discuss] Fill interior volumes of a Nef_polyhedron_3
  • To:
  • Subject: Re: [cgal-discuss] Fill interior volumes of a Nef_polyhedron_3
  • Date: Fri, 22 May 2015 02:21:19 +0000
Hello Sebastien,
That was very useful.  The class Mark_bounded_volumes does not appear to be described in the documentation, but it certainly did the trick.  I will do some profiling, but expect to see a big improvement.
Thank-you.
On Tue, 5 May 2015 at 02:44 Sebastien Loriot (GeometryFactory) <> wrote:
On 05/03/2015 03:48 AM, Robert W. Johnstone wrote:
> Hello Everyone,
> I have a function to fill the unmarked interior volumes of a
> Nef_polyhedron_3.  The function work by extracting all of the shells,
> converting them to Polyhedron_3, and then joining all of the components
> together using nary union.  As you can imagine, this is computationally
> intensive.
> If I had access to the internal structures, I would walk all of the
> finite volumes, set the mark to true, and then simplify the structure.
> Is such an approach possible?
> Thank-you,
> Robert
> Robert W. Johnstone
> In theory, there is no difference between theory and practice.
> In practice, there is.
I think you can use the class Mark_bounded_volumes for this purpose.
Something like the following should be working:
Nef_3 nef;
CGAL::Mark_bounded_volumes<Nef_3> marker;
nef.delegate(marker);
HTH,
Sebastien.
