cgal-discuss - [cgal-discuss] switching to AABB_face_graph_triangle_primitive.h
  • To: CGAL Discuss <>
  • Subject: [cgal-discuss] switching to AABB_face_graph_triangle_primitive.h
  • Date: Wed, 6 May 2015 14:53:54 +0000
  • Accept-language: en-US
  • Authentication-results: inria.fr; dkim=none (message not signed) header.d=none;
I have a C++ program that uses the CGAL library, installed using macports.   The program was working perfectly.  However, after upgrading to CGAL 4.5.2_0, started getting many compile-time warnings that the CGAL/AABB_polyhedron_triangle_primitive.h header is deprecated and that I now should start using CGAL/AABB_face_graph_triangle_primitive.h.  The program continued to compile, but I started to get weary of the warnings.   So I naively switched the header name and also added the CGAL/boost/graph/graph_traits_Polyhedron_3.h header file which now seems to be necessary to interface with the Boost Graph Library.  I noticed also from examples in the CGAL documentation that one of my `typedefs` needed to be updated from
    typedef CGAL::AABB_polyhedron_triangle_primitive<K,Polyhedron> Primitive;
to
    typedef CGAL::AABB_face_graph_triangle_primitive<Polyhedron> Primitive;
And so far, that is the extent of what I have done.  But now I am getting two new errors at compile time, and I have no idea what they mean.  They seem to be internal to the various CGAL header files I am using:
    In file included from ./Particle.h:44:
    /opt/local/include/CGAL/AABB_tree.h:810:27: error: no matching conversion for functional-style cast from 'CGAL::internal::In_place_list_iterator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<My_facet<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<My_items>, std::__1::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Vector_3<CGAL::Epick> > > >, std::__1::allocator<CGAL::HalfedgeDS_in_place_list_face<CGAL::I_Polyhedron_facet<My_facet<CGAL::HalfedgeDS_list_types<CGAL::Epick, CGAL::I_Polyhedron_derived_items_3<My_items>, std::__1::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Vector_3<CGAL::Epick> > > > > >' to 'Primitive' (aka 'CGAL::AABB_face_graph_triangle_primitive<CGAL::Polyhedron_3<CGAL::Epick, My_items, HalfedgeDS_default, std::__1::allocator<int> >, CGAL::Default, CGAL::Boolean_tag<true>, CGAL::Boolean_tag<false> >')
                        m_primitives.push_back(Primitive(first));
    In file included from ./Particle.h:45:
    /opt/local/include/CGAL/AABB_traits.h:63:33: error: no matching member function for call to 'construct_shared_data'
    m_primitive_data=Primitive::construct_shared_data();
    /opt/local/include/CGAL/AABB_tree.h:268:15: note: in instantiation of member function 'CGAL::internal::AABB_tree::AABB_traits_base<CGAL::AABB_face_graph_triangle_primitive<CGAL::Polyhedron_3<CGAL::Epick, My_items, HalfedgeDS_default, std::__1::allocator<int> >, CGAL::Default, CGAL::Boolean_tag<true>, CGAL::Boolean_tag<false> >, true>::set_shared_data' requested here
    {m_traits.set_shared_data();}
At this point I am lost.  If anyone has experience switching from the deprecated header file to the new one, I will be grateful for any advice you might have about how I should proceed.
I can include the header file for the Particle class that seems to be the problem, but it is 3282 lines long and I'm not sure which part(s) I should include.
Best regards,
Jeffrey W. Bullard, Ph.D.
Materials and Structural Systems Division
National Institute of Standards and Technology
