Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors
- To:
- Subject: Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors
- Date: Wed, 06 May 2015 10:01:20 +0200
Le 06/05/15 03:06, Adam Getchell a écrit :
Hello all,
I’m attempting to implement the (2,6) move which may be described
pictorially as:
Hi Adam,
My questions:
1. Is it correct to delete the two old cells before creating the new ones?
It is correct, as long as you don't lose their neighbors, which will be neighbors of the new cells.
However it might be more efficient not to delete them, but just modify them, and create only the 4 additional cells needed.
You may want to have a look at how flips are implemented in Triangulation_data_structure_3.h
2. Is there a way to create a vertex without inserting it into the
Delaunay triangulation?
You must certainly not insert a point in the Delaunay triangulation, in general it cannot give you what you want. You should only use and patch TDS.
look for create_vertex in
http://doc.cgal.org/latest/TDS_3/classTriangulationDataStructure__3.html
Other modifiers
The following modifiers can affect the validity of the triangulation data structure.
3. If not, is there a way to prevent the Delaunay triangulation from
re-triangulating with the newly inserted vertex before other operations
are created?
NA
4. What is the correct way to create new cells in a region with older ones?
I don't understand this question, but I hope/guess that my answers above will help for this one as well.
5. How do I know that I need to change orientation
Look at section 1 (Representation) in the User manual of 3D Triangulation Data Structure, the (non-geometric) notion of orientation is explained.
Best,
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
- [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors, Adam Getchell, 05/06/2015
- Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors, Adam Getchell, 05/06/2015
- Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors, Monique Teillaud, 05/06/2015
- Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors, Adam Getchell, 05/07/2015
- Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors, Olivier Devillers, 05/07/2015
- [cgal-discuss] Problem on Poisson Surface reconstruction, 11硕博 隋伟, 05/07/2015
- Re: [cgal-discuss] Invalid TDS after inserting vertices and creating cells & neighbors, Monique Teillaud, 05/07/2015
