- To:
- Cc: Martin Landa <>
- Subject: [cgal-discuss] Natural neighbor interpolation
- Date: Tue, 19 May 2015 18:56:24 +0200
Also I have a vector "function_values" for these points:
function_values.insert(std::make_pair(Point(x,y),z));
I'd like to save into a grid values interpolated within the region containing these points.
So far I have code that works but is quite slow, because I have to go throw the grid step-by-step by cols and rows to define point p K::Point_2 p(coor_x,coor_y) and call the CGAL::natural_neighbor_coordinates_2 for each single step.
Is there any option how to fill the grid in different way?
Thanks in advance
Adam Laza
CTU Prague
/* perform NN interpolation */
G_message(_("Computing..."));
Delaunay_triangulation T;
typedef CGAL::Data_access< std::map<Point, Coord_type, K::Less_xy_2 > >
Value_access;
T.insert(points.begin(), points.end());
//coordinate computation in grid
double coor_x, coor_y;
coor_x = window.west;
coor_y = window.north;
for (int rows=0 ; rows<window.rows ; rows++) {
G_percent(rows, window.rows, 2);
for (int cols=0 ; cols<window.cols ; cols++) {
K::Point_2 p(coor_x,coor_y);
std::vector< std::pair< Point, Coord_type > > coords;
Coord_type norm = CGAL::natural_neighbor_coordinates_2(T, p,std::back_inserter(coords)).second;
Coord_type res = CGAL::linear_interpolation(coords.begin(), coords.end(), norm, Value_access(function_values));
G_debug(5, "x: %f y: %f -> res: %f (row=%d; col=%d)",
coor_x, coor_y, res, rows, cols);
coor_x += ewres;
std::cout << res << " ";
coor_y -= nsres;
std::cout << std::endl;
G_percent(1, 1, 1);
- [cgal-discuss] Natural neighbor interpolation, Adam Laža, 05/19/2015
