cgal-discuss - Re: [cgal-discuss] Bug with Delaunay triangulation in CGAL?
  • To:
  • Subject: Re: [cgal-discuss] Bug with Delaunay triangulation in CGAL?
  • Date: Thu, 21 May 2015 00:47:43 +0200
Le mardi 19 mai 2015 07:42:44 LTH a écrit :
> Hi,
> Yes, that is what I mean: on the first system it works well from
> inside/outside VS. On the second system it only works inside VS, the result
> is wrong and different each time I run manually the compiled .exe file. And
> I am sure that I run the correct file. If I copy that file and run it on the
> first system, it works perfectly. All the input data, used libraries and
> compiling settings are same on both systems.
Can you tell us more about your code? Maybe you should even share it with us.
That might help.
I understand that the results are no reproductible, from one run to another.
Do you iterator over the content of associative containers? The comparison
operators of CGAL handles/iterators are usually not deterministic, because
they rely on comparisons of pointer values. That might explain the behavior
of
the code.
Can you explain what you consider wrong in the results you have? You say that
you use 2D Delaunay triangulations. Are the triangulations valid after
construction?
Laurent Rineau, PhD
