cgal-discuss - Re: [cgal-discuss] CGAL::linear_interpolation
  • To:
  • Subject: Re: [cgal-discuss] CGAL::linear_interpolation
  • Date: Fri, 22 May 2015 10:54:24 +0200
IIUC, you have a grid of input points right?
Did you first checked that the value at the grid point are identical
because it's not clear to me on the pictures.
Sebastien.
On 05/21/2015 06:37 PM, Adam Laža wrote:
Hi all,
I use CGAL::linear_interpolation function in my GRASS GIS modul
v.surf.nn that provides natural neighbor interpolation for 2D scattered
data. Code works well, I write down the results into an output raster
map. But the output differs a lot from another outputs.
For same data I use GRASS GIS modul v.surf.nnbathy (this module uses
nn-c library) and ESRI ArcGIS tool Natural neighbor. Output of these
tools are identical. But the output of v.surf.nn using CGAL is
completely different.
Any idea what's going wrong?
Thanks in advance
Adam
ArcGIS output: http://oi60.tinypic.com/ou17c4.jpg
GRASS GIS (v.surf.nnbathy): http://oi60.tinypic.com/ml4jd5.jpg
GRASS GIS (v.surf.nn using CGAL): http://oi58.tinypic.com/208k9du.jpg
Code:
/* perform NN interpolation */
G_message(_("Computing..."));
/* triangulation */
Delaunay_triangulation T;
typedef CGAL::Data_access< std::map<Point, Coord_type, K::Less_xy_2 > >
Value_access;
T.insert(points.begin(), points.end());
//coordinate computation in grid
double coor_x, coor_y;
coor_x = window.west;
coor_y = window.north;
for (int rows=0 ; rows<window.rows ; rows++) {
G_percent(rows, window.rows, 2);
if (mask)
Rast_get_c_row(maskfd, mask, rows);
for (int cols=0 ; cols<window.cols ; cols++) {
/* don't interpolate outside of the mask */
if (mask && mask[cols] == 0) {
Rast_set_d_null_value(&dcell[cols], 1);
continue;
K::Point_2 p(coor_x,coor_y);
std::vector< std::pair< Point, Coord_type > > coords;
Coord_type norm = CGAL::natural_neighbor_coordinates_2(T,
p,std::back_inserter(coords)).second;
Coord_type res = CGAL::linear_interpolation(coords.begin(),
coords.end(), norm, Value_access(function_values));
G_debug(5, "x: %f y: %f -> res: %f (row=%d; col=%d)",
coor_x, coor_y, res, rows, cols);
coor_x += ewres;
//std::cout << res << " ";
dcell[cols] = (DCELL) res;
coor_y -= nsres;
//std::cout << std::endl;
Rast_put_d_row(fd, dcell);
G_percent(1, 1, 1);
