Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop
- To:
- Subject: Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop
- Date: Wed, 27 May 2015 08:26:41 +0200
What you write would hold for any class.
for(...){
std::vector<int> V = FunctionThatCreatesAVector()
std::cout << &v << std::endl;
Your FunctionThatCreatesAVector()
should create a vector<int> with new
and then return the pointer.
andreas
On 27/05/2015 07:55, Daniel Abler wrote:
Dear List,
I would like to create a list of pointers to Polyhedron_3 objects (created in
a loop) for later meshing via Polyhedral_mesh_domain_3, as in the following
pseudocode:
struct K: public CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Polyhedron_3<K> Polyhedron;
std::list<Polyhedron*> poly_pointer_list;
for (...)
Polyhedron cgalpoly =
FunctionThatCreatesCgalPolyhedronFromVTKPolyData;
poly_pointer_list.push_back(&cgalpoly);
The problem here is that &cgalpoly always points to the same address... I
suspect this has to do with the 'copy constructor' of Polyhedron_3 or my
'FunctionToCreateCgalPolyhedronFromVTKPolyData'.
How can I make sure that each cgalpoly created in the loop is kept in memory
and can be addressed by an unique pointer?
Many thanks,
Daniel
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop, Daniel Abler, 05/27/2015
- Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop, Andreas Fabri, 05/27/2015
- Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop, Daniel Abler, 05/27/2015
